I posted this on the beginner forums but it didn't get traction. Maybe it requires more advanced knowledge. I'm running 6.30.2 on a RB450G and can't seem to get static ip leases to work within the DHCP server on some IP cameras I have. I've tried to manually enter them in and also convert a dynamic lease into a static lease with "Make Static" but the cameras just take DHCP no matter what. Any suggestions?
Config below:
/export
aug/06/2015 18:40:25 by RouterOS 6.30.2
software id = 2CBR-CW2K
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
add name=dhcp ranges=192.168.1.10-192.168.1.254
add add-arp=yes address-pool=dhcp always-broadcast=yes bootp-lease-time=
lease-time bootp-support=dynamic disabled=no interface=
ether2-master-local lease-time=1m name=default
/ip settings
set rp-filter=strict
add address=192.168.1.1/24 comment="default configuration" interface=
ether2-master-local network=192.168.1.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=
no interface=ether1-gateway
/ip dhcp-server config
set store-leases-disk=never
/ip dhcp-server lease
add address=192.168.1.64 client-id=1:xxxxxx mac-address=
xxxxxxx
add address=192.168.1.10 client-id=" camera-front" mac-address=
xxxxxx
add address=192.168.1.11 client-id=camera-m mac-address=xxxxx
add address=192.168.1.12 client-id=camera-b mac-address=xxxx
add address=192.168.1.13 client-id=camera-t mac-address=xxxxx
add address=192.168.1.0/24 comment="default configuration" gateway=
192.168.1.1 netmask=24
/ip dns static
add address=192.168.1.1 name=router
add action=drop chain=input comment="Drop Input Invalid" connection-state=
invalid
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=
established,related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration"
add chain=forward comment="default configuration" connection-state=
established,related
add action=drop chain=forward comment="default configuration"
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-port=xxxx in-interface=ether1-gateway
protocol=tcp to-addresses=xxxxx to-ports=xxxx
protocol=tcp to-addresses=xxxx to-ports=xxxx
/ip service
set telnet disabled=yes
set ftp address=192.168.1.0/24
set www address=192.168.1.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/system clock
set time-zone-name=America/Chicago
/system ntp client
set enabled=yes primary-ntp=66.220.10.2 secondary-ntp=216.152.240.220
/tool bandwidth-server
set enabled=no
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool romon port
add
