I am not sure if this is a bug, but this is what happens.
I have MT with three lan adapters. One is used for external network and two other for two local networks on ip ranges 10.30.0.0/24 (lan1) and 10.31.0.0/24 (lan2).
I have computer connected to lan1 and I’ve set static Ip lease 10.30.0.1 to computer based on his MAC.
I have this settings:
lan1-pool (10.30.0.1 - 10.30.255.255)
lan2-pool (10.31.0.1 - 10.31.255.255)
lan1-dhcp (interface=lan1; address-poool=lan1-pool; authoritative=yes)
lan2-dhcp (interface=lan2; address-poool=lan2-pool; authoritative=yes)
lease (address=10.30.0.1; mac=)
When this computer is connected to lan1 everything works fine. But, since this computer is used for testing, I want to attach it to lan2 occasionaly, to be able to test settings for that lan. When I do that, MT still recognizes computer by it’s MAC and again attaches IP 10.30.0.1 which is inapropriate, since computer is no more connected to lan1 and cannot work using that address.
I expected different behaviour of MT: DHCP should matter static leases only if computer is attached to lan which actualy uses that IP range.
On other router I used to maintain, I could set static lease rules like this:
“if computer using this MAC is attached to this lan adpater then give it this IP.”
That allowed me not just that set static lease for the computer only if it is attached to proper lan, but also to give it different lease if atached to other lan.
