Static DNS/DNS lookup not working
On my home network, I've got static DNS entries set-up for internal devices:
/ip dns static
add address=192.168.0.7 name=shadowfax.lan type=A
DHCP is configured to direct DNS to my router so I can do nslookup shadowfax.lan on Windows and it returns correctly:
PS 27/06/2026 11:06:34>nslookup shadowfax.lan
Server:  router001.lan
Address:  192.168.0.1
Non-authoritative answer:
Address:  192.168.0.7
However at a client site this doesn't work. If I try nslookup router001.lan, it returns this:
PS C:\Program Files\PowerShell\7> nslookup router001.lan
Server:  UnKnown
Address:  192.168.88.1
*** UnKnown can't find router001.lan: Non-existent domain
nslookup bbc.co.uk doesn't work either although DNS is clearly resolving as ping.bbc.co.uk works.
The main difference between my home set-up and this client is they use NextDNS sink holing so DNS is configured to use DoH:
admin@ROUTER001] > /ip dns print
                      servers:
              dynamic-servers: 194.168.4.123
                               194.168.8.123
               use-doh-server: https://dns.nextdns.io/87f42b/ROUTER001
              verify-doh-cert: yes
   doh-max-server-connections: 5
   doh-max-concurrent-queries: 50
                  doh-timeout: 5s
        allow-remote-requests: yes
          max-udp-packet-size: 4096
         query-server-timeout: 2s
          query-total-timeout: 10s
       max-concurrent-queries: 100
  max-concurrent-tcp-sessions: 20
                   cache-size: 2048KiB
                cache-max-ttl: 1w
      address-list-extra-time: 0s
                          vrf: main
           mdns-repeat-ifaces:
                   cache-used: 97KiB
Their configuration:
# 2026-06-27 11:09:33 by RouterOS 7.23.1
# software id = 31UI-6J08
# model = RB2011UiAS
# serial number = *moderator's edit*
/caps-man channel
add band=2ghz-g/n extension-channel=XX name=2g
add band=5ghz-a/n/ac extension-channel=XXXX frequency=\
    5500,5660,5580,5260,5180 name=5g
add admin-mac=DC:2C:6E:70:8A:F9 auto-mac=no name=bridge port-cost-mode=short
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-gig
set [ find default-name=ether3 ] name=ether3-gig
set [ find default-name=ether4 ] name=ether4-gig
set [ find default-name=ether5 ] name=ether5-gig
set [ find default-name=ether6 ] name=ether6-fast
set [ find default-name=ether7 ] name=ether7-fast
set [ find default-name=ether8 ] name=ether8-fast
set [ find default-name=ether9 ] name=ether9-fast
set [ find default-name=ether10 ] name=ether10-fast
set [ find default-name=sfp1 ] advertise="10M-baseT-half,10M-baseT-full,100M-b\
    aseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full"
/interface vlan
add comment="Forces guests onto 10.0.0.x" interface=bridge name=public-vlan \
    vlan-id=10
/caps-man datapath
add bridge=bridge name=private
add bridge=bridge name=public vlan-id=10 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk name=private
add authentication-types=wpa-psk,wpa2-psk name=public
/caps-man configuration
add channel=2g country="united kingdom" datapath=private installation=indoor \
    mode=ap name=2g-private security=private ssid=bridgend-private
add channel=5g country="united kingdom" datapath=private \
    datapath.local-forwarding=yes installation=indoor mode=ap name=5g-private \
add channel=2g country="united kingdom" datapath=public installation=indoor \
    mode=ap name=2g-public security=public ssid=bridgend-public
add channel=5g country="united kingdom" datapath=public \
    datapath.local-forwarding=yes installation=indoor mode=ap name=5g-public \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
/interface lte apn
/interface wifi datapath
add bridge=bridge disabled=no name=private
add bridge=bridge disabled=no name=public vlan-id=10
/interface wifi security
add authentication-types=wpa-psk,wpa2-psk disabled=no name=private
add authentication-types=wpa-psk,wpa2-psk disabled=no name=public
/interface wifi configuration
add country="United Kingdom" datapath=private disabled=no name=2g-private \
    security=private ssid=bridgend-private-2g
add country="United Kingdom" datapath=private disabled=no name=5g-private \
    security=private ssid=bridgend-private-5g
add country="United Kingdom" datapath=public disabled=no name=2g-public \
    security=public ssid=bridgend-public-2g
add country="United Kingdom" datapath=public disabled=no name=5g-public \
    security=public ssid=bridgend-public-5g
add name=private ranges=192.168.88.10-192.168.88.254
add name=public ranges=10.0.0.10-10.0.0.254
add address-pool=private interface=bridge lease-time=4h name=private
add address-pool=public interface=public-vlan lease-time=1h name=public
/ip smb users
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/system script
add dont-require-permissions=no name=NextDNS owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    \_NextDNS IP update. Although Virgin Media is static, this script triggers\
    \_the IP address @ NextDNS to be updated. When NextDNS receives the simple\
    \_HTTP request, it updates it's internal database with the public IP addre\
    ss.\r\
    \n\r\
    \n# Private profile.\r\
    \n/tool fetch https://link-ip.nextdns.io/87f42b/47f587944a1aaed0\r\
    \n\r\
    \n# Public profile.\r\
    \n/tool fetch https://link-ip.nextdns.io/3cde4e/47f587944a1aaed0\r\
    \n\r\
    \n# Remove downloaded file.\r\
    \n/file remove \"47f587944a1aaed0\""
/caps-man access-list
add allow-signal-out-of-range=10s comment="Rob's tablet" disabled=no \
    mac-address=52:71:C5:84:B3:9E ssid-regexp=""
add allow-signal-out-of-range=10s comment="Rob's mobile" disabled=no \
    mac-address=4E:13:35:FE:44:B2 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Rob's laptop" disabled=no \
    mac-address=00:45:E2:81:E4:61 ssid-regexp=""
add allow-signal-out-of-range=10s comment=PRINTER002 disabled=no mac-address=\
    B4:B6:86:A8:6C:C5 ssid-regexp=""
add allow-signal-out-of-range=10s comment=PRINTER001 disabled=no mac-address=\
    B0:22:7A:BD:BD:8B ssid-regexp=""
add comment=DESKTOP012 disabled=no mac-address=90:DE:80:63:99:65
add comment="DESKTOP010 Bev" disabled=no mac-address=90:DE:80:F3:46:54
/caps-man manager
set enabled=yes package-path=/pub/ upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=g master-configuration=\
    2g-private name-format=prefix-identity name-prefix=2g \
    slave-configurations=2g-public
add action=create-dynamic-enabled hw-supported-modes=a master-configuration=\
    5g-private name-format=prefix-identity name-prefix=5g \
    slave-configurations=5g-public
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2-gig \
    internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3-gig \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4-gig \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5-gig \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6-fast \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7-fast \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8-fast \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9-fast \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10-fast \
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 \
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=ether1-wan list=WAN
add interface=public-vlan list=VLAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE:6E:23:B0:F9:B9 name=ovpn-server1
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
    none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2g-private \
    name-format=2g-private-%I slave-configurations=2g-public supported-bands=\
    2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=5g-private \
    name-format=5g-private-%I slave-configurations=5g-public supported-bands=\
    5ghz-ac
    192.168.88.0
add address=10.0.0.1/24 interface=public-vlan network=10.0.0.0
/ip dhcp-client
add comment=defconf interface=ether1-wan name=ether1
/ip dhcp-server lease
add address=192.168.88.242 client-id=1:18:fd:74:d1:36:d7 mac-address=\
    18:FD:74:D1:36:D7 server=private
add address=192.168.88.228 client-id=1:b0:22:7a:bd:bd:8b mac-address=\
    B0:22:7A:BD:BD:8B server=private
add address=192.168.88.226 client-id=1:54:ab:3a:1f:36:82 mac-address=\
    54:AB:3A:1F:36:82 server=private
add address=192.168.88.197 client-id=1:ec:8e:b5:70:ed:ff mac-address=\
    EC:8E:B5:70:ED:FF server=private
add address=192.168.88.188 client-id=1:b4:b6:86:a8:6c:c5 mac-address=\
    B4:B6:86:A8:6C:C5 server=private
add address=10.0.0.0/24 comment="Public network" dns-server=\
    45.90.28.115,45.90.30.115 gateway=10.0.0.1
add address=192.168.88.0/24 comment="Private network" dns-server=192.168.88.1 \
    gateway=192.168.88.1
set allow-remote-requests=yes use-doh-server=\
    https://dns.nextdns.io/87f42b/ROUTER001 verify-doh-cert=yes
/ip dns static
add address=45.90.28.0 name=dns.nextdns.io type=A
add address=45.90.30.0 name=dns.nextdns.io type=A
add address=2a07:a8c0:: name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: name=dns.nextdns.io type=AAAA
add address=192.168.88.1 name=router001.lan type=A
add action=accept chain=input comment="accept established,related,untracked" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP (ping)" protocol=icmp
    "accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
    "Allow DNS from VLAN to LAN based DNS server" dst-address=192.168.88.1 \
    dst-port=53 in-interface-list=VLAN protocol=udp
add action=drop chain=input comment="drop all not coming from LAN inc. VLAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="accept in ipsec policy" \
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" \
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=\
    "fasttrack - disables queues" connection-state=established,related
    "accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="FTP port forward" dst-port=21 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.88.197
/ip ipsec profile
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/lcd
set backlight-timeout=5m
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/London
/system identity
set name=ROUTER001
/system scheduler
add comment="Update NextDNS public IP" interval=2h name="NextDNS IP update" \
    on-event="/system script run NextDNS" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2023-01-18 start-time=16:00:00
/tool graphing interface
add interface=ether1-wan
/tool mac-server
/tool mac-server mac-winbox
More info - the computer being used it hard wired (so no Wi-Fi in way) and this is the IP configuration:
PS C:\Program Files\PowerShell\7> ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : SERVER002
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-LM
   Physical Address. . . . . . . . . : EC-8E-B5-70-ED-FF
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.88.197(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 17 June 2026 17:59:46
   Lease Expires . . . . . . . . . . : 27 June 2026 14:00:03
   Default Gateway . . . . . . . . . : 192.168.88.1
   DHCP Server . . . . . . . . . . . : 192.168.88.1
   DNS Servers . . . . . . . . . . . : 192.168.88.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
I believe this is more or less a binary setting, you use doh server or you don't.
if you do, nothing else will be used, i.e. this:
/ip dns static
should behave exactly as:
/ip dns static
I TAKE IT BACK. :astonished_face:
This was probably true only for old versions of RouterOS v6.x
I hope to get onto site over the next week so I can try turning DoH off whilst connected directly. Too risky remotely!
Yes, unfortunately DoH has not been implemented as as another lookup server but rather as a complete replacement of the DNS client.
So you cannot combine DoH with other features of the DNS client. Maybe that should be more apparent from the UI... (i.e. once you enable DoH many other options become greyed out)
That's a pretty big flaw IMO? Unless I'm missing something. It means you can't have any local static DNS entries for servers, access points etc?
But also not sure it's all or nothing. I've turned on Google DoH on my home network and the static DNS entries are still resolving. However, what I don't know is the DoH server is actually been used. Maybe another column on the cache display would be useful - some indication of what was used to resolve these addresses.
Static entries do get resolved even if DoH is enabled. Your problem is somewhere else.
Get the exact answers that the Mikrotik returns a la dig. There are quite a few pitfalls. Just to mention one: if the computer detects ipv6, the A and AAAA records are queried in parallel, and the AAAA may return NXDOMAIN. Returning a valid A and NX for the AAAA should not be possible - if there is no AAAA, NODATA is correct.
This was just one example. There can be all sorts of things.
I thought that must be the case. And yes, the problem lies elsewhere.
bangs my head against the wall - how many times is this going to catch me out. This client uses NextDNS sink holing. They're running the NextDNS client on each PC which routes DNS requests directly via the NextDNS servers. So of course static DNS on the router is not used!
Sorry for wasting everyone's time!
You can define static dns entries in nextdns directly.
