I have Mikrotik CCR and a few Unifi U6-Pro AP with 4 VLAN in the configuration.
- VLAN 10 for office network
- VLAN 20 for Wi-Fi network
- VLAN 30 for guest
- VLAN 40 for device
and the problem is, I have static DNS in Mikrotik with VLAN 10 network but when user connect with Wi-Fi network(VLAN20) they cannot access via DNS name, but when using IP it connected. and I already set up DNS server for VLAN 20 network which is VLAN 10 network. is there additional settings need for resolve DNS in VLAN ?
Router
add interface=VLAN100 list=VLAN-Network
add interface=VLAN110 list=VLAN-Network
add interface=VLAN99 list=VLAN-Network
add interface=VLAN80 list=VLAN-Network
add address=192.168.100.1/23 interface=VLAN100 network=192.168.100.0
add address=192.168.110.1/24 interface=VLAN110 network=192.168.110.0
add address=192.168.80.1/24 interface=VLAN80 network=192.168.80.0
add address=192.168.99.1/24 comment="Device WiFi Address" interface=VLAN99 \
network=192.168.99.0
add address=192.168.80.0/24 dns-server=8.8.8.8 gateway=192.168.80.1
add address=192.168.99.0/24 dns-server=192.168.100.1 gateway=192.168.99.1
add address=192.168.100.0/23 dns-server=192.168.100.1 gateway=192.168.100.1
add address=192.168.110.0/24 dns-server=192.168.100.1 gateway=192.168.110.1
set allow-remote-requests=yes cache-max-ttl=1d servers=\
8.8.8.8,1.1.1.1,192.168.100.1
Switch
add admin-mac=78:9A:18:E1:0D:68 auto-mac=no name="Bridge to Router" \
port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=qsfpplus1-1 ] disabled=yes
set [ find default-name=qsfpplus1-2 ] disabled=yes
set [ find default-name=qsfpplus1-3 ] disabled=yes
set [ find default-name=qsfpplus1-4 ] disabled=yes
set [ find default-name=qsfpplus2-1 ] disabled=yes
set [ find default-name=qsfpplus2-2 ] disabled=yes
set [ find default-name=qsfpplus2-3 ] disabled=yes
set [ find default-name=qsfpplus2-4 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] comment=BondingToSwitchCore
set [ find default-name=sfp-sfpplus3 ] comment=BondingToSwitchLAN
set [ find default-name=sfp-sfpplus5 ] comment=BondingToSwitchAP
set [ find default-name=sfp-sfpplus7 ] comment=BondingToSwitchServer
set [ find default-name=sfp-sfpplus9 ] disabled=yes
set [ find default-name=sfp-sfpplus10 ] disabled=yes
set [ find default-name=sfp-sfpplus11 ] disabled=yes
set [ find default-name=sfp-sfpplus12 ] disabled=yes
set [ find default-name=sfp-sfpplus13 ] disabled=yes
set [ find default-name=sfp-sfpplus14 ] disabled=yes
set [ find default-name=sfp-sfpplus15 ] disabled=yes
set [ find default-name=sfp-sfpplus16 ] disabled=yes
set [ find default-name=sfp-sfpplus17 ] disabled=yes
set [ find default-name=sfp-sfpplus18 ] disabled=yes
set [ find default-name=sfp-sfpplus19 ] disabled=yes
set [ find default-name=sfp-sfpplus20 ] disabled=yes
set [ find default-name=sfp-sfpplus21 ] disabled=yes
set [ find default-name=sfp-sfpplus22 ] disabled=yes
set [ find default-name=sfp-sfpplus23 ] disabled=yes
set [ find default-name=sfp-sfpplus24 ] disabled=yes
/interface bonding
add mode=802.3ad name=BondingToRouter slaves=sfp-sfpplus1,sfp-sfpplus2 \
transmit-hash-policy=layer-2-and-3
add mode=802.3ad name=BondingToSwitchAP slaves=sfp-sfpplus5,sfp-sfpplus6 \
add mode=802.3ad name=BondingToSwitchLAN slaves=sfp-sfpplus3,sfp-sfpplus4 \
add mode=802.3ad name=BondingToSwitchServer slaves=sfp-sfpplus7,sfp-sfpplus8 \
/interface vlan
add interface=BondingToRouter name=VLAN99 vlan-id=99
add bridge="Bridge to Router" ingress-filtering=no interface=BondingToRouter \
internal-path-cost=10 path-cost=10
add bridge="Bridge to Router" ingress-filtering=no interface=\
BondingToSwitchLAN internal-path-cost=10 path-cost=10
add bridge="Bridge to Router" interface=BondingToSwitchAP internal-path-cost=\
10 path-cost=10 pvid=99
add bridge="Bridge to Router" interface=BondingToSwitchServer \
/interface bridge vlan
add bridge="Bridge to Router" tagged="BondingToRouter,BondingToSwitchLAN,Bridg\
e to Router,BondingToSwitchServer" untagged=BondingToSwitchAP vlan-ids=99
add bridge="Bridge to Router" tagged="BondingToRouter,BondingToSwitchLAN,Bondi\
ngToSwitchServer,BondingToSwitchAP" vlan-ids=100
add bridge="Bridge to Router" tagged=\
BondingToRouter,BondingToSwitchAP,BondingToSwitchLAN vlan-ids=110
BondingToRouter,BondingToSwitchAP,BondingToSwitchLAN vlan-ids=70
add bridge="Bridge to Router" tagged=BondingToRouter,BondingToSwitchServer \
vlan-ids=50
BondingToRouter,BondingToSwitchAP,BondingToSwitchLAN vlan-ids=80
config.txt (4.39 KB)
