Hey,
I have a set of IPs (of an online service [lets name them y.y.y.1-4) i’d like to connect to via my other addresses.
What i mean, my ISP gave me a pool of /29 so I use x.x.x.1 as my main one.
What i’m trying to do is to use x.x.x.2 (same pool same interface) to connect to those y.y.y.1-4
My initial thought was, that adding x.x.x.2 to the address list, and y.y.y.1, y.y.y.2 … with x.x.x.2 as gw to the / ip routes should work , but after a brief testing, i can tell that all packets to y.y.y.y are still going through default gateway.
I am a little tired, so probably i’m making some obvious rookie mistake, but please, can some help me sort this out?
I’m pretty sure i’ve done it in the past, and i do not recall this being even remotely hard… Am i missing some distance/scope/targetscope parameters, or NAT rule or something? It’s literally just 4 IPs, manual setting would work just fine, but i seem to miss something…
