I hava a openvpn tun client on centos7(ip addr: 192.168.88.111)
iptables -t nat -A POSTROUTING -d 10.19.0.0/16 -o tun_go_aws -j MASQUERADE
# 10.19.0.0/16 Its my aws private cidr
on openwrt I add a static route, as a lan gateway to connect aws. and everything works fine.
10.19.0.0/16 192.168.88.111
but, on mikrotik(RB750Gr3), I add a same static route too, everything work slow.
especially establish, like ssh to server or open http request, it always toke like 10s.
If you (still) have fasttracking enabled (there’s a rule with action=fasttrack), then try to disable it. Fasttracking interferes with many things if the rule is not adjusted according to particular use case and symptoms are often same as what you observe.
