Static Ip Routing Without Isp
I have two routers, Router A & Router B is connected to my P2p link,
p2p link is connected by rocket m-5 Router.
I wan’t to static Ip Routin in Wthout Isp
Mikrotik Router A: 10.10.10.52/24 Lan port 3
Mikrotik Router A: 192.168.2.1/24 lan port 2
Mikrotik Router B: 10.10.10.51/24 lan port 3
Mikrotik Router B: 192.168.1.99/24 Lan Port 2
I have configure below Ip Route in MT Router.
Route:IP route add dst-address=192.168.1.0/24 gateway=10.10.10.51
Route:IP route add dst-address=192.168.2.0/24 gateway=10.10.10.52
in your local network you do what you want - add different subnets and add routes in each subnet how other your local subnets can be reached. Remember, each subnet has to know about other subnets. If you want it to be separate from your ISP then you have to use NAT, so that all the outgoing traffic source address is masked to one, that your ISP can route to.
Thanks sir for your given positive feedback.i am new in mikrotik Router.
i don’t use any isp for static routing. p2p link is ok but i don’t get ip address ping to both network 192.168.1.0/24,192.168.2.0/24.
how can i connect two different network in this P2P Link?
please see attached My network map Image.
please help me.
