i´m a little bit new in ISPs Business
in the past i uses MLPPP over ADSL and SDSL with static IP-Aadresses on the PPPoE Connections.
No problem to assign Static-IP to Client uses Radius.
But from know on i uses my own System to bundle my Connections.
I hosted a RB1200 in Datacenter, and build EOIP Tunnels to them and uses Bonding-Interface.
The only thing I’m not able to todo is routing static IP to my Client.
I standing at the wall don’t seeing the hole.
Provider gives my 62.216.xxx.xxx/25 on hosted Routerboard.
PAST:
DSL------!.-.-.- PPPoE Connections to ISP (Routerboard 1100)User Manager and PPPoE Server -.-.-.- PPPoE to Clients
---------! with Static IP addresses
Future:
RB1200 at Datacenter -------------Multiple DSL Lines—RB1100------PPPoE to CLients
Bonding Interface has
62.216.xxx.2 62.216.xxx.3
62.216.xxx.1 ist Gateway (ISP)
On Datacenter side i bridged Eth1 and the Logical Interface Bonding together. On my side i assign the IP 62.216.xxx.3 to my RB1100 and it available from the Internet.
DOing NAT to the Bonding Interface works great.
If i bridge Bonding Interface and PPPoE Serveron my side problems start.
if got much problems with PMTU Blackhole.
is there an another way to do this?
thanks for help
mistry7
