Static IP to Net working, Dynamic No go
I setup my cable modem to a linksys router (NAT), if i tell the routerboard to use Gateway 192.168.0.1 (Linksys) then internet works.
If I attached cable modem direct to RB and add DHCP Client to that port, it will get the correct External IP, but I can not get out to the web. (It is auto adding the Cable companies Gateway)
what am i doing wrong?
Do you have a masquerade on the RB when connected directly to the modem?
add chain=srcnat action=masquerade out-interface=ether1
no.. Didnt know had to do anything different.. but that would make sense :wink:
Ill try it thanks!
