Hi.
I have the following seup.
Eth1 62.38.167.2/25 (Lan Interface)
Eth2 192.168.1.1/24
Nat Router 192.168.1.254 /24 Port Eth2 (DSL Line)
Eth3 62.38.167.3/25
Cisco Router 62.38.167.1/25 Port Eth3 (Leased Line)
Eht2 Has masquarading enabled.
I have a clients behind Eth1 interface with ip range 62.38.167.0/25.
I cant enable nat on eth3 as it wouldnt allow me to use static ips.
I do a policy routing so basically one type of packets is passed through Nat router and some should pass through Cisco router with static ip of the client.
The problem is that i dont know what i should do in order the routing to work between 62.38.167.3 and 62.38.167.1.
Can anybody help?
What about Bridging Eth1 and Eth3, and giving the Bridge interface IP 62.38.167.2
-K
Thank you for your response.
Yes thats possible and i tried it (not exactly as you suggesting) but it seems that mikrotik didnt mangle the traffic correctly after that. And i was not able to descriminate the traffic comming from lan. I will do reconfiguration and try again but if there any other way i would really like to hear it.
