Hi!
I’ve a Mikrotik RB760iGS with 3 Gateway (ADSL 1 for internet of all computer, ADSL 2 used only for VoIP connections and ADSL 3 for specifics works), I’ve some statics route that force all outcoming traffic to specific ip addresses to be routed to ADSL 2, they are all VoIP server and PBX, that’s simple to make because I know the remote addresses, now I need to force a specific local PC on the LAN to go out only by ADSL 3 because there are some pc that must dialog by a specified network, but I don’t know the remote ip addresses, how can I do?
Now I’m using Mangle marking package coming from specific lan ip address with a word:
- chain: prerouting,
- src. address: 192.168.1.10,
- action: mark routing,
- new routing mark: siss
than under routes I make a route using that mark to force a specific gateway:
- dst. address 0.0.0.0/0,
- gateway: 192.168.10.254,
- type: unicast,
- distance: 1
- scope: 30
- target scope: 10
- routing mark: siss
It goes but looks like that there is something that make network really slow, how can I do it better and faster?
# jul/15/2019 09:51:22 by RouterOS 6.45.1
# software id = KKNC-EV7A
# model = RB760iGS
# serial number = AXXXXXXXXXX
add name=bridge-LAN
set [ find default-name=ether1 ] name=ether1-Voce speed=100Mbps
set [ find default-name=ether2 ] name=ether2-WAN1 speed=100Mbps
set [ find default-name=ether3 ] name=ether3-LTE speed=100Mbps
set [ find default-name=ether4 ] name=ether4-SISS speed=100Mbps
set [ find default-name=ether5 ] name=ether5-LAN speed=100Mbps
/interface gre
add local-address=161.1.2.77 name=gre-N4Com remote-address=161.2.2.2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_pool-LAN ranges=192.168.9.70
add address-pool=dhcp_pool-LAN disabled=no interface=bridge-LAN lease-time=1d \
name=dhcp-LAN
/system logging action
set 3 bsd-syslog=yes remote=86.11.12.216 syslog-facility=local0
add bridge=bridge-LAN interface=ether5-LAN
add interface=bridge-LAN list=LAN
add interface=ether2-WAN1 list=WAN
add interface=ether1-Voce list=WAN
add interface=gre-N4Com list=WAN
add address=82.10.23.118/30 interface=ether1-Voce network=82.10.23.116
add address=82.10.23.110/30 interface=ether2-WAN1 network=82.10.23.108
add address=192.168.9.150/24 interface=bridge-LAN network=192.168.9.0
add address=161.1.2.77/30 interface=ether3-LTE network=161.1.2.76
add address=161.1.2.86/30 interface=gre-N4Com network=161.1.2.84
add address=192.168.10.50/24 interface=ether4-SISS network=192.168.10.0
/ip dhcp-server lease
add address=192.168.9.70 client-id=1:0:xx:xx:xx:xx:xx mac-address=\
00:xx:xx:xx:xx:xx server=dhcp-LAN
add address=82.10.23.116/30 gateway=82.10.23.118
add address=192.168.9.0/24 gateway=192.168.9.150
set servers=128.65.200.80,8.8.8.8
add action=accept chain=input src-address=17.18.27.120/29
add action=accept chain=input src-address=17.18.28.128/29
add action=accept chain=input src-address=17.18.29.80/29
add action=accept chain=input src-address=17.18.30..195
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
protocol=icmp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=siss passthrough=no \
src-address=192.168.9.203
add action=dst-nat chain=dstnat disabled=yes dst-port=888 protocol=tcp \
to-addresses=192.168.9.70 to-ports=80
add action=dst-nat chain=dstnat dst-port=8291 protocol=tcp to-addresses=\
192.168.9.150 to-ports=8291
add action=dst-nat chain=dstnat dst-port=161 protocol=udp to-addresses=\
192.168.9.150 to-ports=161
add action=dst-nat chain=dstnat protocol=icmp to-addresses=192.168.9.150
add action=src-nat chain=srcnat out-interface=gre-N4Com to-addresses=\
82.10.23.110
add action=masquerade chain=srcnat comment="IP Masquerade"
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=192.168.10.200 routing-mark=siss
add check-gateway=ping distance=10 gateway=82.10.23.109
add distance=10 gateway=gre-N4Com
add distance=30 gateway=82.10.23.117
add distance=5 dst-address=27.9.9.114/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.9.114/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.9.114/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.10.6/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.10.6/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.10.6/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.11.19/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.11.19/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.11.19/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.11.20/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.11.20/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.11.20/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.11.21/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.11.21/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.11.21/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.12.15/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.12.15/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.12.15/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.12.16/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.12.16/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.12.16/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.13.34/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.13.34/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.13.34/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.14.231/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.14.231/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.14.231/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.15.92/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.15.92/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.15.92/32 gateway=gre-N4Com
add distance=5 dst-address=27.9.15.93/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.15.93/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.15.93/32 gateway=gre-N4Com
add distance=1 dst-address=172.17.0.0/20 gateway=ether3-LTE
add distance=1 dst-address=161.2.2.0/30 gateway=ether3-LTE
add distance=5 dst-address=27.9.16..175/32 gateway=82.10.23.117
add distance=10 dst-address=27.9.16..175/32 gateway=82.10.23.109
add distance=20 dst-address=27.9.16..175/32 gateway=gre-N4Com
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Rome
/system identity
set name="Mikrotik"
/system logging
set 0 action=remote prefix=INFO
set 1 action=remote prefix=ERROR
set 2 action=remote prefix=WARN
set 3 action=remote prefix=CRIT
add action=remote prefix=FW topics=firewall
add action=remote prefix=HEALTH topics=health
/tool mac-server
/tool mac-server mac-winbox
