Static route problem with Hotspot
I am running a RB433 with Hotspot connected to another RB433 bridged.
My routing table is
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE IN..
0 S 0.0.0.0/0 r 192.168.1.254 2 ether1
1 ADS 0.0.0.0/0 r 192.xxx.xxx.xxx 1 pppoeout
2 ADC 10.5.50.0/24 10.5.50.1 0 Hotspotbridge
3 A S 172.16.0.0/16 r 10.5.50.10 1 Hotspotbridge
4 ADC 192.168.1.0/24 192.168.1.1 0 ether1
The first RB433 is 10.5.50.1/24 on the bridge which is running a hotspot and the 2nd 10.5.50.10/24 on its bridge.
On the 10.5.50.10/24 it also has a new network on the 172.16.0.0/16 range.
I want to be able to get from 10.5.50.1 to 172.16.0.0/16.
I have added a static route as you can see in rule 3 above but it doesn’t work with the hotspot enabled, as soon as i disable the hotspot it is OK.
I have a ip-binding for 10.5.50.10 with the hotspot by-passed.
Is there something else i need to add here or can it not be done through a hotspot.
Thanks in advance
Ben
I think you should add 10.5.50.10 IP address to ip-binding with type=bypassed, then it should work.
