static routes besides Dynamic ones
i have 2 Adsl Connections, (served via Bridge-mode modems) the RB750 makes the PPPoe and also manages the traffic.
pretty much straight forward. both connections are active and the router decide which one to use (perfect failover)
i have 2 Maqurade rules active and have all port forwardings added twice as well ..
so everything works no matter what connection is active.
i would like to have some of the traffic always use the same interface based on either local IPadress or the remote destination.
or much better would be to be able to set a Preferred Internet connection for certain Destinations or internal source IP’s
is that possible to do ?
since the default routes are added by the pppoe client i have no way to manage them …
also have not figured out how to add priorities to routes as well ..
