Static Routing (can't ping)
Hello!
I would to do static route for 2 mikrotik
and tried to look for answer here with no luck :frowning:
MK1
2 Wan Load Balance (192.168.1.2 , 192.168.2.2)
eth2: 192.168.88.1
MK2
eth0: 192.168.88.2
eth1: 192.168.100.1
I am able to ping from MK2 to MK1
Internet is ok from MK2
but I fail to ping from MK1 to MK2
from winbox(MK1 and MK2) I am able to ping/tracert all ip within 192.168.100.x or 192.168.88.x
but MK1’s PC, i couldn’t ping at all
Mk2’s PC, i am able to ping MK1 and with internet access.
what did i set wrong here?
Thanks in advance.
MK1 route
 0 A S  0.0.0.0/0                          192.168.1.1               1
 1 A S  0.0.0.0/0                          192.168.2.1               1
 2 A S  0.0.0.0/0                          192.168.1.1               1
 3  DS  0.0.0.0/0                          192.168.1.1               1
 4  DS  0.0.0.0/0                          192.168.2.1               1
 5   S  0.0.0.0/0                          192.168.2.1               2
 6 ADC  192.168.1.0/24     192.168.1.2     WAN1                      0
 7 ADC  192.168.2.0/24     192.168.2.2     WAN2                      0
 8 ADC  192.168.88.0/24    192.168.88.1    Local                     0
 9 A S  ;;; route 2F
        192.168.100.0/22                   192.168.88.2              1
MK2 route
 0 ADS  0.0.0.0/0                          192.168.88.1              1
 1 A S  192.168.88.0/22                    192.168.88.1              1
 2 ADC  192.168.88.0/24    192.168.88.2    ether1-gateway            0
 3 ADC  192.168.100.0/24   192.168.100.1   ether2-master-l...        0
in one place you have /22 in other /24 what are details for ip addresses added?
All i can say - double check your configuration.
still new to networking
i have no idea what i am doing with /22 and /24
i copy from example of static routing but couldn’t get it to work.
Could you please explain in detail regards the setting I should cross check?
Thanks.
btw, this is my address from both MK
i change the route to /24 now.. but still same.
MK 1
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.88.1/24    192.168.88.0    Local
 1 D 192.168.2.2/24     192.168.2.0     WAN2
 2 D 192.168.1.2/24     192.168.1.0     WAN1
MK 2
     192.168.100.1/24   192.168.100.0   ether2-master-local
 1 D 192.168.88.2/24    192.168.88.0    ether1-gateway
Do you have anything in “/ip firewall nat” or “/ip firewall filter” that might stop that?
Add: If you are going to route the network, there should be no NATs except in the core router (MK1).
Hello!
There is only default rule in nat and firewall.
I just tried to disable all but still could not ping :frowning:
Thanks!
MTK2  Firewall
0 X ;;; default configuration
     chain=input action=accept protocol=icmp
 1 X ;;; default configuration
     chain=input action=accept connection-state=established
 2 X ;;; default configuration
     chain=input action=accept connection-state=related
 3 X ;;; default configuration
     chain=input action=drop in-interface=ether1-gateway
MTK2 NAT
     chain=srcnat action=masquerade to-addresses=0.0.0.0
     out-interface=ether1-gateway
How about NAT and firewall rules in MK1? Anything there?
MTK 1 is doing some filtering for facebook, youtube and QoS.
MTK1  firewall filter
 0   chain=forward action=drop src-address=192.168.88.119
 1   chain=forward action=accept src-address-list=admin_user_dl_list
     layer7-protocol=web-facebook
 2   chain=forward action=accept src-address-list=sp_user_dl_list
 3   chain=forward action=accept src-address=192.168.88.124
 4   chain=forward action=accept src-address-list=admin_user_dl_list
     layer7-protocol=web-youtube
 5   chain=forward action=accept src-address-list=sp_user_dl_list
 6   ;;; facebook
     chain=forward action=drop src-address=192.168.88.2-192.168.88.255
 7   ;;; youtube
 8   ;;; yahoo msg
     layer7-protocol=yahoo msger
 9 X ;;; google plus
     chain=forward action=drop protocol=tcp
     src-address=192.168.88.2-192.168.88.255 dst-port=80
     content=plus.google.com
10 X ;;; google plus
     src-address=192.168.88.2-192.168.88.255 dst-port=443
11 X chain=forward action=drop src-address=192.168.88.2-192.168.88.255
     layer7-protocol=qq
12   ;;; default configuration
13   ;;; default configuration
14   ;;; default configuration
15 X ;;; VPN
     chain=input action=accept protocol=tcp dst-port=1723
16 X ;;; VPN
     chain=forward action=accept protocol=gre
17   ;;; default configuration
     chain=input action=drop in-interface=WAN1
18   ;;; default configuration
     chain=input action=drop in-interface=WAN2
MTK 1  NAT
1   chain=srcnat action=masquerade out-interface=WAN1
 2   chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=WAN2
 3   ;;; VPN internet passthrough
     chain=srcnat action=masquerade src-address=192.168.10.0/24
 4   ;;; port forwarding
     chain=dstnat action=dst-nat to-addresses=192.168.88.53 to-ports=47494
     protocol=tcp dst-port=47494
 5   chain=dstnat action=dst-nat to-addresses=192.168.88.53 to-ports=43634
     protocol=udp dst-port=43634
Why is this here? Which device is assigned that address?
What is the ip of the computer on MK1 (192.168.88.x) that can’t ping? It may make it easier to troubleshoot if I knew that.
MTK1 PC’s
can’t ping anything actually
I tried 192.168.100.1 to 192.168.100.50 (which is all valid of course in MTK 2)
meanwhile, MTK2 can ping all and with internet access. :confused:
Thank you for trying to help!
Can you ping 192.168.88.1 from those same computers? How about 192.168.88.2?
PC1: 192.168.88.53
able to ping 192.168.88.1 192.168.88.2
fail to ping 192.168.100.1 - 192.168.100.50
PC2: 192.168.100.254,
(gateway: 192.168.100.1 DNS: 192.168.88.1)
able to ping 192.168.100.1 - 192.168.100.50
What method are you using for load balancing? I suspect you are using PCC, which means you are using routing marks to route the traffic.
If that is the case, on the first router, you should add a rule which does not process the traffic from LAN1 to LAN2 through the PCC rules:
/ip firewall mangle
add chain=prerouting src-address=192.168.88.0/24 dst-address=192.168.100.0/24 action=accept
This rule should sit above the others.
you are right!!
thank you!! i could ping now!
