Static routing un hotspot 2.9.x
Hallo All,
This is urgent :slight_smile:
I’ve configure hotspot in 2.9.x is very simple. but when.
I’ve using Static routing with public IP in client. and bandwidth manajemen the other mcahine with bridge.
problem is…
port 80 and 53 on WAN interface dst to my IP Mikrotik, no client IP. so i cannot get IP client in downstream my bandwidth manajemen. (thats like private IP)
Can i get solution for this problem.
Thanks A lot..
ASH
Hii Anybody here??
please talk u’re experience about this..
how can i bypass port 80 and 53 with real routing. no to http proxy on hotspot 2.9.x.
Thanks… All.
ASH
Simple use firewall NAT to redirect these ports on firewall filter to block them, you can’t do anything with the ports in the routing
