Static Routing
Hi
I am new to Mikrotik routers having worked a bit with Cisco. I am having problems with static routing. I have set up a simple test network using 2 PC’s and a RB433ah. the problem I have is that pc 1 can ping pc 2 but pc 2 cant ping pc 1. I have attached a simple schematic. The RB is default except for addresses and default route. I am at a loss as to what I have missed. Can someone put me straight please as this is really frustrating.
routes.pdf (7.72 KB)
Check the gateway on the computer with 192.168.1.2/24. You are showing the gateway as 192.168.2.1.
It should be 192.168.1.1.
And the default route on the router should be
dst-address=0.0.0.0/0
You show
dst-address=0.0.0.0/24
Sorry both are typo’s.
The default route is 0.0.0.0/0 and the gateway on 192.168.1.2 is 192.168.1.1
If those are typos, then please post “/ip firewall nat” and “/ip firewall filter”.
I am going to ask first about the nat. If there is a rule like this
chain=srcnat action=masquerade
Then disable it It might have more parameters, but in this case you want no srcnats or masquerades.
disable X
[admin@MikroTik] /ip firewall nat> print
[admin@MikroTik] /ip firewall nat> ..
[admin@MikroTik] /ip firewall> filter
[admin@MikroTik] /ip firewall filter> print
Host firewalls.
Thanks fewi. I knew it would be something simple. Thought I was going mad!!! All working now. THANKS
