We are having issues with Static trace. We have RB1200 Firmware 3.07, Package Version 5.26.
196.6.242.1 (RB1200)
196.6.242.30(Linux Server)
41.162.57.148(Provider SBC)
172.24.29.17(Provider Gateway) __Static:
8 A S ;;; Crossconnect
dst-address=41.162.57.148/32 gateway=172.24.29.17 gateway-status=172.24.29.17 reachable via ether5 distance=1 scope=30 target-scope=10
From the Router to 41.162.57.148:
/tool traceroute 41.162.57.148
ADDRESS RT1 RT2 RT3
1 172.24.29.17 1ms 1ms ms
2 0.0.0.0 0ms 0ms 0ms_** From Server to 41.162.57.148 ;
[root@kensington ~]# tracepath 41.162.57.148
1: 196.6.242.30 (196.6.242.30) 0.136ms pmtu 1500
1: 196.6.242.1 (196.6.242.1) 0.282ms
2: no reply
3: no reply
From the Server the second hop should be 172.24.29.17 as it is on the router. That is the provider Gateway.
196.6.242.30(Linux Server) ↔ locally connected to ↔ 196.6.242.1 (RB1200) ↔ taking internet from ↔ 172.24.29.17(Provider Gateway) <—> would like to see 41.162.57.148(Provider SBC)
And you need the Mikrotik configuration for that
Have I understand well
196.6.242.30(Linux Server) <--> locally connected to <--> 196.6.242.1 (RB1200) <--> taking internet from <--> 172.24.29.17(Provider Gateway) <---> would like to see 41.162.57.148(Provider SBC)
@stenlyto, All the routing is configured. The issue is that when doing a traceroute from the Mikrotik to 41.162.57.148(Gateway 172.24.29.17.
From Router:
ADDRESS RT1 RT2 RT3
From Server:
2: no reply
3: no reply
The Traceroute from the Server does not show the Gateway to 41.162.57.148 witch is 172.24.29.17
