i need to static routing
how to this
when any pc require 192.168.0.0/24 go to gateway 192.168.0.210
plz help asap
how to this
plz help asap
Add default route 0.0.0.0/0 to that gateway of yours.
do it but not working :
Can you post your setup? If its all configured properly, it should be ok.
ok
i will tell you scenario
Head Office
1- Local Netwrok
2- Mikrotik Firewall RB2011UiAS-RM ip = 192.168.0.1
3- G.SHDSL Router ip= 192.168.0.210
Branch 2
1- Local Netwrok
2- Mikrotik Firewall RB2011UiAS-RM ip = 192.168.1.1
3- G.SHDSL Router ip= 192.168.1.210
ok I need when any pc in head office require 192.168.1.0/24 go to 192.168.0.210
and when any pc in branch 2 require 192.168.0.0/24 go to 192.168.1.210
i was remove firewall
and setup configuration from router adsl and every thing be ok
That’s not gonna work.
192.168.x.x is a private range, and not routable over the internet.
If you want communication between the two locations, build a VPN tunnel (pptp, lt2p, sstp) between them and route the designated traffic over that tunnel.
we have g.shdsl - copper line
and working all routers and firewall but i need work on mikrotik ???
only when any pc require range ip example 192.168.0.0/24 require 192.168.1.0/24 routing 192.168.0.210
and there is all routers normal billion - cisco - any router but in mikrotik i don’t know where this option
Option Name In all Routers (Static Routing)
