Static WAN IP and Route help
I have never used a static IP for wan… usually just PPPoE. However I have used statics on other gear. I added the IP to the WAN interface. Pinging from the terminal, I get a “no route”. So I add one and get ping time outs.
I was given an IP of x.x.98.146 and a GW of x.x.98.145 (i.e. /30).
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   ;;; hotspot network
     192.168.8.1/24     192.168.8.0     192.168.8.255   ether2
 1   1.1.98.146/30    1.1.98.144    1.1.98.147    WAN
 0 A S  0.0.0.0/0                          1.1.98.145       1
 1 ADC  1.1.98.144/30    1.1.98.146    WAN                0
 2 ADC  192.168.8.0/24     192.168.8.1     ether2             0
Am I missing something ? I have added my laptop to the IP bindings bypass for the hotspot… and disabled all firewall filters. Still nothing.
1.1. = X.X.
Your address and route config looks OK, so maybe problem is located outside MikroTik/RouterOS. Try to connect your laptop directly to WAN (I suppose this is ADSL modem or something similar) and check connection.
Regards, Grzegorz.
That is what I was thinking, however I am connected via wifi to the mikrotik. The WAN link goes across the wireless backhaul. I will have to check it tomorrow as it is on a hospital roof. I just wanted to make sure that I was not missing anything obvious.
Success… someone had the wrong port tagged upstream… all is well.
