Station mode does not work, "SEARCHING FOR NETWORK&quot
Hi guys
I have installed routeros only since 3 days ago.
I am using Atheros 5212 PCI and Via and Dlink ethernet AMD 1600 CPU ASUS motherboard, I have here 2 AP, one is senao and other is InterEpoch but i cannot make it connect to AP in station mode, have set the SSID/Band/Frequency antenna and etc all properly, and even APs show up in Scan window but when I connect to them it only says “SEARCHING FOR NETWORK”.
Note: system working fine in hotspot and can do client authenticating and all stuff.
What does the /l p w command say? Is an interface connecting and disconnecting or just not connecting?
thans for prompt reply
it seems it is connectecing only for less than a second and its keep going like that
if you are using the 2.8.18 then there are no problems with it as far as we know. maybe make a supout.rif file and send to support
ap side mac filter usuali does the same
