Hallo,
I have a hap AX lite and routeros 7. Since wifiwave 2 does not have a repeater mode, I want to connect in station mode to another router and use the net via ether2 with a cable. Give some advice how this can be done ![]()
Hallo,
I understand you want to use it as the L2 ethernet extender?! Use station bridge mode for the wifi and put the interface on the bridge with others ethernet ports if the main wireless router is a Mikrotik device with same wireless drivers,or use station pseudobridge mode! If you want to extend the wifi just add to the bridge virtual wifi interface in AP mode with same SSID and password.
i see.
should i put dhcp client on wifi to get an address from the main router?
