station modes are not working
I have a hap lite device, it was used as a wifi-to-wire bridge (station pseudobridge mode), and it used to work as expected earlier.
But now, when I started my setup after some time, it doesn’t work anymore
It just doesn`t want to connect to wifi, and I do not understand why
I tried different station modes, checked security profiles - all looks fine and not working
Can someone help ?
Yes, only you can do that.
With our help
https://forum.mikrotik.com/viewtopic.php?p=908118
Check your device settings
Try a firmware update
The problem was found here
/interface/wireless/connect-list/print
There was a rule allowing specific ap only.
To figure this out I had to enable logging for wireless driver
/system/logging/add topics=wireless action=memory
