Station PsudeoBridge
I have just put in a rb133c to replace a litestation 5 Bridge. I am running v3.0rc1 and have setup bridging and have the wireless setup in station psudobridge mode. It connects and works, but my speeds are very strange. The upload will be 4 to 5 meg but the download is 200k. If I change over to routing and route a small subnet over to it, it works fine. Any suggestions where I should start looking would be great.
Mark Spencer
Anyone know, how to set up the Pseudobridge mode?
Tried setting it up, but can’t get traffic through the subscriber end
Regards
I added the ether1 and the wlan1 to a bridge, then set the mode on the wlan1 card to station psudo-bridge.
That was all there was to it
Thanks very much for replying -
Hmm - that’s what I did, no joy.
What did you do at the AP end?
Not using WDS (of course) or Nstreme (yet) for that matter on this attempt
Regards
AP Side is just an ap doing dhcp. You should be able to test if it works on any AP, Linksys, netgear, any cheap thing just to see if you are briding the connection when you connect to it
