Statistic doesn't populate after reset-counters
I manually reset counters through the winbox queue simple menu for one queue. But after that winbox did not restart populating statistics which means despite the fact that I even restarted the ROUTER, all other queues was reset and restart counting statistics but the one I reset myself is still at 0.
Please, how can I populate statistics from that specific queue? I am looking for it since two days without any solution.
Thanks!
RouterOS 6.1, MikroTik RB2011iUAS.
I realized that reset counters is not properly working when rates are set to “unlimited” because their values are equal to zero. So I put values to Rx/Tx rates and Winbox started populating downloaded values.
http://wiki.mikrotik.com/wiki/Manual:Queue#Simple_Queues
If all properties of a queue have default values (no set limits, queue type is default), and queue has no children, then it is not actually created.
