Is there a way to get the stats on a single filter rule via the CLI?
I have one I need to check periodically and don’t really need to see the 65 others. If I could get this to work, I could have the router email it to me with the other stuff it sends at midnight every day.
Add a comment to your filter rule, then edit the script below to match. Run this in the terminal to output a sample. Remove starting/ending curly braces in your final script as they are only needed for the local variables when running in the terminal.
