I saw many posts on if UPnP works properly on ROS and if is compatible with XBox Live.
What is the final status on this with ROS 3.x (I am using 3.28 and 3.30 on my NAT devices)
http://forum.mikrotik.com/t/xbox-live-and-ros-3-0rc13/17921/68
Currently it’s fixed. You need to use v4.10 to have all fixes.
I am considering upgrading from ver 3 to ver 4 so that I can enable UPnP for XBox live users, but I am nervous lest I get swamped with lots of other peer to peer stuff sucking up bandwidth.
Is there any way that I can limit the UPnP so that it only allows the XBox stuff through? Or maybe there is a way of setting up specific firewall rules?
I am using HOTSPOT. Any ideas if the latest ver 4 support Xbox live UPnP with hotspot?
I would also appreciate any detailed instructions on how to enable UPnP.
thanks and regards
Jim
You can enable Upnp to see what rules it creates, then create them manually and disable Upnp.
Thanks Normis. Good suggestion! Does the UPnP for Xbox work OK with HotSpot??
Jim
