Hy,
I get this error: “pppoe,ppp,error : could not add UPnP interface: std failure: broken path (2)”
the RB is a RB110AHx4 (6.42.3 ) and the CPU runs over 50%.
Any idea why i get this error?
thanks
Hy,
thanks
/ip UPnP is not enabled
I still get this error in every 15 minutes
Looks like a bug with PPP profile when UPnP is disabled globally. Make sure UPnP is set to ‘no’ or ‘default’ under PPP profile (make sure you edit profile you’re actively using)
