std failure
ver:6.10 x86
mangle in.interface:all ppp change mss:1360 or 1440 or..
out.interface:all ppp change mss:1440
Automatically appear ip-mangle-change mss, after disabling the mangle in, log the following tips:
log:
could not change mangle rule:std failure:unknow id(4)
在 mangle 里,自动出现了change mss ,并且重启设备后,每次出现的 new tcp mss 值都不一样,有时会变成 1440 ,有时会变成 1360,请问一下,为什么会出现这个呢?对拨号用户有什么影响吗?
In the mangle, the automatic emergence of change mss, and reboot the device after, new tcp mss value is not the same for each occurrence, sometimes turns into 1440, sometimes turns into 1360, to ask, why is there about this? What is the impact on dial-up users do?
您好,请尝试更新到6.11版本,请检查是否仍有问题
你好,问题依旧。
This problem never happen to me.
Write one e-mail to support@mikrotik.com attaching the file supout.rif generated clicking on the button “Make Supout.rif” inside winbox.
对不起,我不知道怎么帮你
:frowning:
降级成5.26正常了。
(for other forum members: “I have reinstalled the 5.26”)
我希望你已经sended的supout.rif 是发现和解决问题的路径
(for other forum members: I hope you have sended the supout.rif, is the path to identify and solve problems)
你好
