Good afternoon!
I'm new to the MikroTik world.
I'm setting up a hap ax2. I have a connection to the provider via L2TP. I just can't get Steam to work (no connection to the servers). Has anyone encountered this problem?
Good afternoon!
[admin@MikroTik] > export hide-sensitive
# 2025-12-19 11:47:26 by RouterOS 7.20.6
add admin-mac=04:F4:1C:86:AF:56 auto-mac=no comment=defconf name=bridge
/interface wifi
set \[ find default-name=wifi1 \] channel.band=5ghz-ax .skip-dfs-channels=
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-86AF5A
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes
.ft-over-ds=yes
set \[ find default-name=wifi2 \] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-86AF5A
.ft-over-ds=yes
/interface l2tp-client
add add-default-route=yes allow=chap connect-to=l2tp.freedom disabled=no
max-mru=1456 max-mtu=1456 name=freedom-l2tp user=pwf60005
add comment=defconf name=WAN
add comment=defconf name=LAN
add add-arp=yes address-pool=default-dhcp interface=bridge lease-time=3d name=
defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add comment=defconf default-route-distance=2 interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat src-address=192.168.88.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
/system clock
set time-zone-name=Europe/Moscow
/tool mac-server
/tool mac-server mac-winbox
backup before and try this
/ip firewall mangle
add chain=forward protocol=tcp tcp-flags=syn action=change-mss
new-mss=clamp-to-pmtu passthrough=yes
add chain=srcnat out-interface=freedom-l2tp action=masquerade
/ip dhcp-client set [find interface=ether1] add-default-route=no
set freedom-l2tp add-default-route=yes
I made the changes. It didn't help. Maybe additional diagnostic data is needed?
Probably not a Mikrotik issue, call roskomnadzor.
I'm not sure the problem isn't with MikroTik. I have a second router (TP-LINK Archer C80), and there are no problems connecting to Steam on it. Appreciated the joke about Roskomnadzor.
ping steam servers starting with small packets and then bigger ones. Check when the ping will stop. Then set that value as new MSS.
