Has anyone got steam streaming over VPN to work between two mikrotiks?
And if so, what config did you use?
The discovery of local steam clients is done using broadcasts. You’d have to be using a single flat ip range and a TAP VPN setup.
HI!
I make worked configuration for streaming over internet with mikrotik.
I have two mikrotik with fixed wan ip.
home network LAN: 192.168.10.0/24 WAN: 85.x.x.x
remote network LAN: 192.168.0.0/24 WAN: 213.x.x.x
Between mikrotik's wan I make eoip with vlan and add vlan into LAN bridge.
HOME settings:
/interface eoip
add clamp-tcp-mss=no local-address=85.x.x.x mac-address=02:51:90:C4:xx:xx name=eoip-vpn remote-address=213.x.x.x tunnel-id=0
/interface vlan
add arp=proxy-arp interface=eoip-spark mtu=1400 name=vlan17 vlan-id=17
add bridge=LAN interface=vlan17
REMOTE settings:
add name=HOME
/interface eoip
add clamp-tcp-mss=no local-address=213.x.x.x mac-address=02:6F:41:37:xx:xx name=eoip-home remote-address=85.x.x.x tunnel-id=0
/interface vlan
add arp=proxy-arp interface=eoip-home mtu=1400 name=vlan-home vlan-id=17
add interface=LAN mtu=1400 name=vlan_vm vlan-id=15
add bridge=LAN interface=ether10
add bridge=HOME interface=vlan-home
add bridge=HOME interface=vlan_vm
Variant 1)
I take vlan 17 from home over VPN and mark as vlan 15 into remote local network bridge.
On remote computer add vlan 15 over main network connection with dhcp client (debian os used as Steam client)
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 40:a8:f0:3f:74:57 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.21/24 brd 192.168.0.255 scope global dynamic eno1
3: vhome@eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1400 qdisc noqueue state UP group default qlen 1000
inet 192.168.10.113/24 brd 192.168.10.255 scope global dynamic vhome
As result you have home ip on remote computer's vlan interface.
Variant 2)
You can add one interface (ether10 for example) into HOME bridge and connect computer into this port.
You device will take home ip address and all traffice will go over vpn into home, as you device will be connected to home router.
Warning! MTU = 1400 on all vlan interfaces for working without packet drops.
All done, you can start steam app and stream you games over internet.
Sorry for my bad english, my primary language is Russian. If you have question, you can write me quick.es@gmail.com.
I read, cant remember where that EOIP and GRE were excellent for multicast streaming as there were no restrictions…
