Is there anywhere a Step by Step Idiots guide for idiots like myself.
I have just spent the morning trying to get into the router sofwtare through my browser to try and use Winbox.
Problem? Do not know the IP Address of the Nic Card that the Sofwtare has given to my interface and therefore do not know the Router Address I have to specify in my browser to get to the Sofwtare and hopefully continue to start using WinBox.
Thank you all for your sugegstions. Have tried everything but still no success.
Tried Winbox with MAC address of the Nic Card through a switch. No success.
Tried configuring IP address to Router Nic Card…still no success trying to connect to Router
Any other sugegstions would be most welcome. I know taht MT have good products but I cannot beleive it is so difficult to get over this first hurdle.
connect keyboard and monitor. if it shows login prompt, write there usernae “admin” and press [enter] key when asked for password. if it does not show the login prompt at all, tell us what happens on the screen.
mac access (MAC-Telnet, MAC-Winbox) does not work on IP level.
however, it does not matter what port you have for ‘www’ accessing router on IP level, Winbox uses 8291 port (2.9 version).
Plug your computer into one of the ethernet ports on the router. Assuming you have a copy of winbox and you’re using the latest version of RouterOS, press the (…) and it should show a list of MAC addresses that are connected to the same segment. Select the MAC address and click connect and you’re in.
Another way is to serial into the device, assign an IP address to the ethernet interface then you can winbox/http to the device based on the IP address you assigned..
Once connected type the following to configure an IP address for a specified interface.
