Hello, i’m new to mikrotik, i’m trying to install it, is there any turtoril or step by step configuration? i’m moving from isa to mikrotik cz its bad,
thank u, please reply
There is a manual. mikrotik.com
i installed it, and i’m connected to it, but i cant access internet, i only need to know how to setup the web proxy if u can help, the manual is complicated, thanx anyway
So you have two issue now, no internet and no webproxy.
Start with the first, make sure you can connect to the internet. More info is needed to help you on this.
Webproxy is something you want to make work after basics are running.
thanks for replying, i’m now connected, and i’m working, but can u help in transparent proxy, how can i configure all messengers to run without entering proxy, i managed to run windows live messenger but it keeps disconneting, and cashing if u could ![]()
