Step up from 493ah
I am running out of ports on a 493ah and would like suggestions on what Mikrotik device is the next step up from it,
the 493ah is used as a switch to combine AP’S + PTP’s, with some of the ports are routed and some bridged.
n21roadie
Currently it is the product, which is discussed for example here,
http://forum.mikrotik.com/t/feature-extension-suggestion-graphing-in-2-9/782/1
RouterBOARD 4xx does not have any model >9 ports at the moment.
