I am trying to setup my hotspot on my hex. Wan is on ether 1. The lan is 192.168.88.0/24 on ether 2 and ether 3-5 are slaved to 2. The dhcp pool is (192.168.88.10-192.168.88.254). I setup the hotspot fine. Simple queue pointed at 12.168.88.0/24) with have pcq limiting set. How should I configure so that the accesspoints (192.168.88.2-192.168.88.9) do not get any bandwidth limiting. The simple queue is pointed at the whole lan, I cannot figure out how to point it at just the dhcp pool. The accesspoints are on that lan but outside of the dhcp.
add a queue with those exception IPs as target in front of all dynamic queues.
Ok, is there anyway to do all in one queue. I does not allow me to put a range in the target. The camper queue is pcq target as the whole lan, which is the queue I want the hardware to bypass. Here is what I did, is this it, and what queue type should be selected on the advanced tab???
