Still have RSTP problems with Mikrotik
What is wrong in my configs?
I use VLAN’s and bridges.
All my devices have tons of log warnings about LOOPs.
See the picture
You don’t show your configs so how can we know what is wrong with them?
Installation SW04 (RBSXTG-5HPacD)
AP BRIDGE
Set the identity
/system identity set name="SW04 - Ring 393"
Create a bridge
/interface bridge add name=BR_BRIDGE-1
Create the needed VLANs
/interface vlan add name=VLAN_LAN_MGMT vlan-id=9 interface=BR_BRIDGE-1
Add an IP address for management
/ip address add address=172.16.5/25 network=172.16.0.0 interface=VLAN_LAN_MGMT
Add a Security Profile
/interface wireless security-profile add name=BRIDGE-1 authentication-type=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key="!@49er4All#$"
Access List vullen voor de Bridge
/interface wireless access-list add mac-address=D4:CA:6D:06:3C:BD interface=wlan1 comment="SW05 Ring 225"
Poorten toevoegen aan bridge
/interface bridge port add interface=ether1 bridge=BR_BRIDGE-1
/interface bridge port add interface=wlan1 bridge=BR_BRIDGE-1
Set Wlan mode
/interface wireless set wlan1 ssid=Bridge1 frequency=auto mode=bridge band=5ghz-onlyac default-authentication=no disabled=no
/interface wireless set wlan1 security-profile=BRIDGE-1 wmm-support=enabled
NV2 Werkt NIET met CAPsMAN
#/interface wireless set wlan1 wireless-protocol=nv2
/interface wireless set wlan1 channel-width=20/40/80mhz-eeeC
/interface wireless set wlan1 default-authentication=no
Create WDS-Interface and add the interface to the bridge
/interface wireless set wlan1 wds-mode=dynamic wds-default-bridge=BR_BRIDGE-1
Globele instellingen
SNTP Client configureren
/system ntp client set primary-ntp=172.16.0.130 secondary-ntp=172.16.0.131 enabled=yes
DNS Instellen
/ip dns set server=172.16.0.130,172.16.0.131
Default route toevoegen
/ip route add dst-address=0.0.0.0/0 gateway=172.16.0.1
SNMP Server configureren
/snmp community
set [ find default=yes ] addresses=172.16.0.60/32
add addresses=172.16.0.60/32 authentication-password=O7ac6eV0TnpLJ155 authentication-protocol=SHA1
encryption-password=hHWhgw91Hed6s4S5 encryption-protocol=AES name=SNMPuser1 security=private
/snmp
set contact=ronald.verheij@skiffkick.nl.nl enabled=yes engine-id=SNMPuser1 location="Ring 393, Pernis, Zolder"
trap-generators=interfaces trap-interfaces=all trap-target=172.16.0.60 trap-version=3 trap-community=SNMPuser1
/snmp community set [find name=public] read-access=no
SYSLOG Server configureren
/system logging action
set 3 remote=172.16.0.20
/system logging
add action=remote topics=warning
add action=remote topics=info
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=wireless
IP SERVICES configureren
/ip service set api disabled=yes
/ip service set telnet disabled=yes
/ip service set ftp disabled=yes
/ip service set api-ssl disabled=yes
/ip service set www address=172.16.0.0/21 disabled=yes
/ip service set www-ssl certificate=WEB_CONF port=4443 disabled=no
Zet de tijdzone goed
/system clock set time-zone-name=Europe/Amsterdam
Route instellen voor locale netwerk
/ip route add dst-address=172.16.0.0/21 gateway=172.16.0.1
What version RouterOS? This was really prevalent a few versions ago but seems to be fixed in newer releases. Try upgrading to latest bugfix.
It is running 6.41
That is not so old I think.
That is not the solution.
Still have these messages.
Note that in most cases the device that has detected loops is not causing the loop.
What this error means is that a packet, that was sent out by the device, is received back after it was forwarded into your network.
You should check devices that are connected to ether1.
We have noticed quite a few configurations that are known to cause issues, make sure sure you are not using this (or one of described) configuration:
https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#VLAN_in_bridge_with_a_physical_interface
Also note that RSTP is not a VLAN aware protocol, it cannot always detect actual loops properly in topology where VLANs are used. You might need to implement MSTP in your network:
https://wiki.mikrotik.com/wiki/Manual:Spanning_Tree_Protocol#Multiple_Spanning_Tree_Protocol
https://wiki.mikrotik.com/wiki/Manual:L … _interface
Think this make sense.
I think I have here a misconfiguration.
On the main router I have this:
Bridge toevogen
add name=BR_LAN_MGMT priority=10
add name=BR_LAN_DATA priority=10
add name=BR_WLAN_DATA priority=10
add name=BR_WLAN_GUEST priority=10
add name=BR_LAN_MFP priority=10
add name=BR_LAN_GAME priority=10
add name=BR_LAN_CAMERA priority=10
add name=BR_LAN_TVMM priority=10
add name=BR_WLAN_SP priority=10
Maak VLANs
/interface vlan
add name=VLAN_LAN_MGMT interface=ether5 vlan-id=9
add name=VLAN_LAN_DATA interface=BR_LAN_MGMT vlan-id=10
add name=VLAN_WLAN_DATA interface=BR_LAN_MGMT vlan-id=12
add name=VLAN_WLAN_GUEST interface=BR_LAN_MGMT vlan-id=14
add name=VLAN_LAN_MFP interface=BR_LAN_MGMT vlan-id=15
add name=VLAN_LAN_GAME interface=BR_LAN_MGMT vlan-id=16
add name=VLAN_LAN_CAMERA interface=BR_LAN_MGMT vlan-id=17
add name=VLAN_LAN_TVMM interface=BR_LAN_MGMT vlan-id=18
add name=VLAN_WLAN_SP interface=BR_LAN_MGMT vlan-id=19
add name=VLAN_LAN_SERVER interface=BR_LAN_MGMT vlan-id=900
Poorten toevoegen aan een bridge
add bridge=BR_LAN_MGMT interface=ether1
add bridge=BR_LAN_MGMT interface=ether5
add bridge=BR_LAN_MGMT interface=VLAN_LAN_MGMT
add bridge=BR_LAN_DATA interface=VLAN_LAN_DATA
add bridge=BR_WLAN_DATA interface=VLAN_WLAN_DATA
add bridge=BR_WLAN_GUEST interface=VLAN_WLAN_GUEST
add bridge=BR_LAN_MFP interface=VLAN_LAN_MFP
add bridge=BR_LAN_GAME interface=VLAN_LAN_GAME
add bridge=BR_LAN_CAMERA interface=VLAN_LAN_CAMERA
add bridge=BR_LAN_TVMM interface=VLAN_LAN_TVMM
add bridge=BR_WLAN_SP interface=VLAN_WLAN_SP
IP adressen toewijzen
Try to set administrative mac address on each bridge (just copy actual mac address). Next time, don’t post your setup script (with wpa2-pre-shared-key=“!@49er4All#$”..) but the rather actual running config:
[admin@MikroTik] > /export hide-sensitive
# mar/23/2018 18:15:21 by RouterOS 6.42rc49
add admin-mac=6C:3B:6B:xx:xx:xx auto-mac=no name=bridge1
