Stop access between 2 LAN
Hi all,
I have an RB750 set up with 2 separate LAN segments:
Office lan: 192.168.10.0/24
Guest lan: 192.168 100.0/24
Switch port 1 set as the gateway
Switch ports 2,3 and 4 set on the office lan
Switch port 5 set on the guest lan
I wish to stop be guest lan from being able to access the office lan.
Can someone provide me with an example firewall rule to do this?
Do you have any forwarding chain rules at the moment? If you don’t then you should read the following and block the inter-LAN traffic as part of generally securing your forwarding paths.
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
The basics are:
Allow NEW connections from each LAN to WAN
Allow ESTABLISHED connections from WAN to each LAN
Allow RELATED connections from each WAN to LAN
Drop everything else
This is what I have so far.
I just set up a hotspot on the guest lan and found that I could no longer access it from the office lan. But I could access the office lan from the guest lan so it’s working the opposite way to how I want it!.
I added
add action=drop chain=forward comment="" disabled=no dst-address=\
    192.168.10.0/24 in-interface=ether5-guest-master
Which seems to have stopped the guest lan from accessing the office lan now. I would like to be able to access the guest lan from the office lan though if that is possible?
This is the full set as it stands now:
[admin@MikroTik] /ip firewall> export
# feb/27/2013 14:22:08 by RouterOS 4.11
# software id = KZR6-A26I
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
add action=accept chain=input comment="default configuration" disabled=no \
    protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established disabled=no in-interface=BT
    connection-state=related disabled=no in-interface=BT
add action=drop chain=input comment="default configuration" disabled=no \
    in-interface=BT
add action=dst-nat chain=dstnat comment=webcam disabled=no dst-port=8000 \
    in-interface=BT protocol=tcp to-addresses=192.168.10.9
add action=dst-nat chain=dstnat comment=xbox disabled=no dst-port=88 \
    in-interface=BT protocol=udp to-addresses=192.168.10.6
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=3074 \
    in-interface=BT protocol=tcp to-addresses=192.168.10.6
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=53 \
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=80 \
add action=dst-nat chain=dstnat comment="" disabled=no dst-port=1863 \
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    no out-interface=BT
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
    disabled=no src-address=192.168.100.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
All help welcome :smiley:
It looks as if you had no forward chain filters prior to adding that one - so in effect you have no “firewall” in the generally accepted meaning. Input chain filters only protect the router itself. Have a look at the wiki entry I referenced earlier. The place you want to be is where your last forwarding rule is a “drop any” and you then have several “accept” rules on the forwarding chain above the “drop any” rule in the execution order. That is really the basis of a firewall.
Great.
I have a whole heap of rules now :smiley:
Still cant access the guest lan from the office lan though :frowning:
Allow NEW connections from office to guest but only allow ESTABLISHED and RELATED in the opposite direction.
Thanks.
I have tried but can’t get it to work :frowning:
Could you give me an example of the rule I should be adding?
Thanks.
