Stop communication inter SSID
Hi guys,
Recently I bought a mikrotik wAP ac, and i have configured two virtual AP (client and guest) on interface WLAN1, and
another two virtual AP (client and guest) on WLAN2 interface.
WLAN1 192.168.20.0/24
WLAN2 192.168.25.0/24
After some tests i can connect to all SSID´s, and i can get out to the web, and also can ping from 192.168.20.1(client on wlan1) the 192.168.25.1 (client on WLAN2) but I do not want that to happen.
How can i block the communication between SSID´s??
Thanks in advance.
Configure the same horizon value on the two port entries for wlan1 and wlan2 in the bridge.
Thanks for tip pe1chl.
I will try, then post the result.
So you don’t want the two networks to communicate with each other - no matter if wired or wreless.
add chain=forward action=drop src-address=192.168.20.0/24 dst-adddress=192.168.25.0/24
add chain=forward action=drop src-address=192.168.25.0/24 dst-adddress=192.168.20.0/24
-Chris
When it is a routing setup that is indeed the correct method. It appears I misread the IP addresses and believed it was a bridged setup.
Thanks for the help Chris!
