Stop Observium picking up all ports on CCR?
Hi Guys
Does anyone know how define which ports observium graphs from a CCR?
We have around 1k PPPoE connections on one of our routers. Observium has detected all of them and is listing them all as ports. I really only want it to graph the WAN port (Eth1) on this particular router.
Any help is gratefully received.
(I dont think observium have a forum, so i thought id check in with other CCR lovers).
You should diabale those nics in the observium.
You can filter nics in the config.php file.
But first look at the observium modules maybe you can disable ppp something.
Good luck
