Stop traffic between Ethernet ports
Hope someone can help
How do you stop traffic routing between networks?
So Have a Microtik with 3 LAN’s sharing same internet connection on ethernet 1
But how do I stop traffic so each internal LAN is seperate
i.e Ethernet 2 cant see the traffic on Ethernet 3
So ethernet 2 = 192.168.1.0/24
EThernet 3 = 172.16.1.0/24
I added a rule into Firewall filter to drop traffic between source 192.16.1.0/24 to destination 172.16.1.0/24 but I could still rdp a server though it?
Regards
Richy
Can you paste your firewall rules?
I have done this to make ether2 only able to send traffic through ether1 (gateway). Glad to hear other options.
/ip firewall filter add action=reject chain=forward in-interface=ether2 out-interface=!ether1
If the lan ports are not in the same bridge just drop all from 2 to 3 and from 3 to 2 in forward chain. Put these rules high enough in the list. This should stop all traffic in between.
Thanks that has worked.
Richy
