Stop using gateway
Hi!
I’m new in mikrotik. I need some help.
My WiFi network(10.90.136.0/24) is on MT 2.9 which connects WiFi with LAN (192.168.1.0/24 gw=192.168.1.1 ADSL). WiFi network card adress is 10.90.136.1 and is gateway for this network(DHCP settings). LAN network card has adress 192.168.1.2. MT has masquerade on and the default route to LAN gateway(192.168.1.1) is added.
I’d like to turn off internet browsing for WiFi users but in the same time I’d like the users can access computers on LAN. Of course LAN user need to have internet browsing on all the time.
Thanks for help.
Regards
I guess you have NAT rules for your clients.
Disallow NAT rule for WLAN traffic and allow only Ethernet traffic.
Hi!
Thanks for answer. Under NAT only masquerade is active.
I’m affraid I don’t know how to disable NAT rules for WLAN traffic. I use winbox for changing MT settings.
Regards.
Changing the In interface on the masquerade rule to the LAN will probably take care of them being able to connect to the internet, you could also restrict it to a certain subnet.
Are the wireless clients currently able to connect to the clients on the LAN?
