Hi dears
I have a Mikrotik router RB951ui-2hnd and i want stop downloading of files. I try many solutions in internet but they doesn’t work.
I want this solution for my job. pleas help me.
Think you.
Hi dears
Think you.
What??? ![]()
Power off the ruterboard, and you stop download anything. ![]()
Port disabling is much less drastic and could be done remotely.
Hi Youlab, it’s impossible to stop the download of all files, you must select which file types you want to block. Maybe you mean P2P?
Maybe it’s a problem in port but can you give a technical explication with details or a link or files.
Think you for your responces
You can block URL with l7 filter, eg, blocking all URL with .exe or .zip
Hi, effectively i try to stop downloading by extensions of files but it doesn’t work, i use this tuto:
http://agratitudesign.blogspot.com/2013/08/limiting-download-file-extensions-on.html
http://agratitudesign.blogspot.com/2013/08/solution-to-limit-youtube-video-streams.html
Think you friends
Better to block all connections which has connection-bytes more then 5-10MB.
