Hellow,I want to remove dude store from mikrotik rb 450 board but I can not when I try to remove it it gives an error like “it’s being used” so it can not be removed so what can I do to disable it ? and remove and I also opend the terminal and did this
/store disable dude
it again gives error that store is used can not be disabled…
so what can I do ?
can anyone answer my questions pleasE ?
G’day,
have you disabled and removed the dude package first?
I believe you will need to disable and remove the package that is using the particular store.
D2.
well,I can’t even see the dude package in the packages list :S I think I might deleted it but not sure
Hi again,
my only suggestion now would be to make a backup
/export file=backup
, then copy the backup to your laptop, then use netinstall to start again!
I do not know of another way to delete the store.
D2.
