Hey guys, need some help over here.
We’re running multiple Mikrotik switches in the network and I cannot find a way to log stp changes. I need to log them because I’m trying to troubleshoot a strange issue with one of our switches that I suspect is related to (R)STP. Problem is that the issue might not occur at all for weeks at a time or it might not occur while I’m physically next to the switch so I cannot log into using a serial cable and check things out (logging in remotely is not an option as the switch is inaccessible while the problem is ongoing). I want to check for STP related events, but I cannot find a way to do it.
WHAT I HAVE TRIED
I have tried using the bridge filter function using the rstp multicast dst mac address 01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF but it does not capture anything. I have tried setting different stp flags like tcn, or tried to match timers (e.g., Hello time 2s) to get a hit. I ended up just making the following rules to log all traffic going through the interface
/interface bridge filter
add action=log chain=input disabled=no in-interface=ether2 log=yes log-prefix=\
testinpu
add action=log chain=output disabled=no log=yes log-prefix=testoutp \
out-interface=ether2
add action=log chain=forward disabled=no in-interface=ether2 log=yes \
log-prefix=testfor out-interface=ether2
For a bit of context I’m not testing on the affected switch. I’m using an RB4011 with RSTP-enabled bridge which I have connected to a bridge port of a hap ax2 that is using RSTP. The above filters do work as I can see lldp and cdp traffic being logged (e.g., 01:80:C2:00:00:0E) but no traffic for RSTP is being reported. I have sniffed packets on the link and bpdus are being properly sent and received, obviously until the topology has converged and the hap ax2 root port stops sending bpdus to the uplink 4011. Notice that the bpdu filters were already configured and running before I connected the devices so it’s not that hap ax2 had already stopped sending bpdus by the time the filters were configured.
I have come across some other similar forum posts but none has apparently reached any conclusion regarding this matter (e.g., http://forum.mikrotik.com/t/stp-logging/67021/1). Appreciate your time!
