STP over PPTP and wireless connection between two sites
I have three links between two sites. Both sites have RB1100AH.
I want to make Link 1 default route.
Link 1: Wireless Connection using ubiquiti radios in WDS mode. (multiple hops between the two sites using Ubiquiti Tought Switch). I have STP enabled on all the switches and radios.
Link 2: PPTP connectoin over ISP1
Link 3: PPTP connection over ISP2
I want Link 1 to take priority (default route). I set the distance on Link 1 to 1 and the Link 2 and Link 3 to 2 and 3.
One of the Tough Switch on Link 1 goes into blocking and the Link 2 is used most of the time.
Can I enable STP on the PPTP connection?
Any ideas how to make the wireless link the priority?
