Hello Guys,
We have a Routed OSPF Net with Cisco Style VPLS Tunnels over BGP.
The MT Interfaces are connected with Wireless UBNT Bridges
here is the config of the two MTs that have Problems and spams the Logs.
MT 1:
add mtu=1500 name=HotSpot priority=0x2000
add mtu=1500 name=MGNT priority=0x2000
add mtu=1500 name=PPPoE priority=0x2000
add mtu=1500 name=lo0
set [ find default-name=ether1 ] comment=PPPoE-Haus
set [ find default-name=ether2 ] comment=Zubr.
set [ find default-name=ether3 ] comment=“AP 2,4G”
set [ find default-name=ether4 ] comment=“AP 5G”
set [ find default-name=ether5 ] poe-out=off
/ip neighbor discovery
set ether1 comment=PPPoE-Haus
set ether2 comment=Zubr.
set ether3 comment=“AP 2,4G”
set ether4 comment=“AP 5G”
/interface vlan
add interface=ether3 l2mtu=1594 name=vlan10-eth3-MGNT vlan-id=10
add interface=ether4 l2mtu=1594 name=vlan10-eth4-MGNT vlan-id=10
add interface=ether3 l2mtu=1594 name=vlan20-eth3-PPPoE vlan-id=20
add interface=ether4 l2mtu=1594 name=vlan20-eth4-PPPoE vlan-id=20
add interface=ether4 l2mtu=1594 name=vlan21-eth3-PPPoEalt vlan-id=21
add interface=ether3 l2mtu=1594 name=vlan30-eth3-HotSpot vlan-id=30
set vlan10-eth3-MGNT discover=no
set vlan10-eth4-MGNT discover=no
set vlan20-eth3-PPPoE discover=no
set vlan20-eth4-PPPoE discover=no
set vlan21-eth3-PPPoEalt discover=no
set vlan30-eth3-HotSpot discover=no
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/routing bgp instance
set default router-id=10.36.1.1
/routing ospf instance
set [ find default=yes ] router-id=10.36.1.1
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/user group
add name=MCDD policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff,sensitive,api”
/interface bridge filter
add chain=forward in-bridge=PPPoE mac-protocol=pppoe-discovery
add chain=forward mac-protocol=pppoe-discovery out-bridge=PPPoE
add chain=forward mac-protocol=pppoe out-bridge=PPPoE
add action=drop chain=forward out-bridge=PPPoE
add action=drop chain=forward in-bridge=PPPoE
add bridge=PPPoE edge=yes external-fdb=no horizon=1 interface=ether1
point-to-point=no
vlan20-eth3-PPPoE point-to-point=no
vlan21-eth3-PPPoEalt point-to-point=no
vlan20-eth4-PPPoE point-to-point=no
add bridge=MGNT edge=yes external-fdb=no horizon=1 interface=vlan10-eth3-MGNT
point-to-point=no
add bridge=MGNT edge=yes external-fdb=no horizon=1 interface=vlan10-eth4-MGNT
point-to-point=no
add bridge=HotSpot edge=yes external-fdb=no horizon=1 interface=
vlan30-eth3-HotSpot point-to-point=no
add bridge=PPPoE edge=yes external-fdb=no interface=ether5 point-to-point=no
/interface ethernet poe settings
set ether1-poe-in-long-cable=yes
/interface vpls cisco-bgp-vpls
add bridge=PPPoE bridge-cost=0 bridge-horizon=9 export-route-targets=
10.36.1.1:0 import-route-targets=10.36.1.1:0 l2router-id=10.0.9.1 name=
PPPoE-FAE route-distinguisher=10.36.1.1:0 vpls-id=10.36.1.1:0
add bridge=HotSpot bridge-cost=0 bridge-horizon=9 export-route-targets=
10.36.1.1:1 import-route-targets=10.36.1.1:1 l2router-id=10.0.9.1 name=
HotSpot-FAE route-distinguisher=10.36.1.1:1 vpls-id=10.36.1.1:1
add address=10.36.1.1/32 interface=lo0 network=10.36.1.1
add address=10.36.1.129/25 interface=PPPoE network=10.36.1.128
add address=10.36.1.65/26 interface=MGNT network=10.36.1.64
add address=10.255.254.34/28 interface=ether2 network=10.255.254.32
/ip dhcp-relay
add dhcp-server=10.255.255.244 disabled=no interface=PPPoE name=relay1
add dhcp-server=10.255.255.244 disabled=no interface=MGNT name=relay2
/ip proxy
set cache-path=web-proxy1 parent-proxy=0.0.0.0
/ip service
/mpls ldp
set enabled=yes lsr-id=10.36.1.1 transport-address=10.36.1.1
/mpls ldp interface
add interface=ether2
/routing bgp peer
add address-families=l2vpn-cisco name=FAE remote-address=10.0.9.1 remote-as=
65530 route-reflect=yes ttl=default update-source=lo0
/routing ospf interface
add interface=ether2 network-type=ptmp
/routing ospf network
add area=backbone network=10.0.0.0/8
/snmp
set enabled=yes
/system clock
/system identity
set name=DD-LGz18-BR-36.1
/system logging
add disabled=yes topics=ospf
/system ntp client
set enabled=yes primary-ntp=10.255.255.225
/tool graphing interface
add
MT 2:
add mtu=1500 name=Hotspot priority=0x2000
set [ find default-name=ether1 ] comment=“PPPoE Haus”
set [ find default-name=ether3 ] comment="A5M19-1oMndsA8 "
set [ find default-name=ether4 ] comment=A2M19-1s1MndsA8
set [ find default-name=ether5 ] comment=A2M19-2s7MndsA8
set ether1 comment=“PPPoE Haus”
set ether3 comment="A5M19-1oMndsA8 "
set ether4 comment=A2M19-1s1MndsA8
set ether5 comment=A2M19-2s7MndsA8
/interface vlan
add interface=ether5 l2mtu=1594 name=vlan10-eth5-MGNT vlan-id=10
add interface=ether5 l2mtu=1594 name=vlan20-eth5-PPPoE vlan-id=20
add interface=ether3 l2mtu=1594 name=vlan21-eth3-PPPoEalt vlan-id=21
add interface=ether4 l2mtu=1594 name=vlan30-eth4-Hotspot vlan-id=30
add interface=ether5 l2mtu=1594 name=vlan30-eth5-Hotspot vlan-id=30
set vlan20-eth5-PPPoE discover=no
set vlan30-eth4-Hotspot discover=no
set vlan30-eth5-Hotspot discover=no
/ip ipsec proposal
set default router-id=10.19.1.1
set [ find default=yes ] router-id=10.19.1.1
set 3 src-address=0.0.0.0
/user group
point-to-point=no
point-to-point=no
add bridge=MGNT edge=yes external-fdb=no horizon=1 interface=vlan10-eth5-MGNT
point-to-point=no
vlan20-eth5-PPPoE point-to-point=no
add bridge=Hotspot edge=yes external-fdb=no horizon=1 interface=
vlan30-eth4-Hotspot point-to-point=no
vlan30-eth5-Hotspot point-to-point=no
point-to-point=no
add bridge=Hotspot edge=no external-fdb=no horizon=9 interface=
vpls-HotSpot-FAE point-to-point=yes
add bridge=PPPoE disabled=yes edge=no external-fdb=no horizon=9 interface=
vpls-PPPoE-FAE point-to-point=yes
10.19.1.1:0 import-route-targets=10.19.1.1:0 l2router-id=10.0.9.1 name=
PPPoE-FAE route-distinguisher=10.19.1.1:0 vpls-id=10.19.1.1:0
add bridge=Hotspot bridge-cost=0 bridge-horizon=9 export-route-targets=
10.19.1.1:1 import-route-targets=10.19.1.1:1 l2router-id=10.0.9.1 name=
HotSpot-FAE route-distinguisher=10.19.1.1:1 vpls-id=10.19.1.1:1
add address=10.19.1.1/32 interface=lo0 network=10.19.1.1
add address=10.19.1.129/25 interface=PPPoE network=10.19.1.128
add address=10.19.1.65/26 interface=MGNT network=10.19.1.64
add address=10.255.254.35/28 interface=ether2 network=10.255.254.32
/ip dhcp-relay
/ip proxy
/ip service
set api disabled=yes
/mpls ldp
set enabled=yes lsr-id=10.19.1.1 transport-address=10.19.1.1
/mpls ldp interface
/routing bgp peer
/snmp
set contact=ddlan enabled=yes location=MndsA8
/system clock
/system identity
set name=DD-MndsA8-BR-19.1
/system logging
/system ntp client
add
As u can see the Wireless Connection is good, the ccq is stable
The MTU at the Bridges is 1524 because of Backbone VLANS
Routeros on both MTs is 6.26
The Problem is both spams the Logs and sometimes the PPPoE Connection over the VPLS Tunnel flaps, But not the BGP.
So what could i do to kill the Problem,
Thanks for any Help
