Strange behavior of MSTP with MVRP
here’s setup (all devices are HEX)
[A]----[1]-----[2]-----[B]
          \[3]/
setup: single vlan (20) with MSTP + MVRP
trunks between 1,2,3 and access ports towards A and B
communication works fine A–1–2–B
when i unplug cable between 1-2 it stops working
nothing goes through backup path A-1-3-2-B
here’s weird part:
if i add bridges on devices 1 and 2 as tagged or untagged to vlan 20 manually
everything works.
can anyone confirm this behavior? is it specific to small switches (HEX)
or does it happen on big CRS.
update: the problem also exists on CRS3xx switches.
does it mean MVRP is not supposed to work with MSTP?
Issue confirmed, we are looking for a fix, thanks!
thank you :slight_smile:
Dear Mikrotik. Has this issue been resolved? Is MVRP usable with MSTP? This is my plan, and VRRP on top of that :slight_smile:
