Strange behavior of wAP ac: Bridge and File
Hi all,
I installed and configured wAP ac as repeater of my wlan, it seems working, but looking at the log I see:
08:13:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:14:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:15:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:16:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:17:21 interface,warning wds1167: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:18:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:19:21 interface,warning wds1167: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:20:21 interface,warning wds1191: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:21:21 interface,warning wds1167: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
the wds167 and wds191 are wds cards belonging to different NICs/Bridge with different MAC address (as reported) and inside the Bridge window (in winbox) the virtual cards are marked as “root port”. I think this error wold be a bug, comparing to a RB912UAG with the same conf, but no errors at all.
Again when I try to connect to wAP ac, very often winbox find both wlan (with the two mac address) offering the same ip, but in the configuration only the bridge own the ip address.
Making any modification the error move to different ports:
08:35:28 interface,warning wds1227: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:36:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:37:21 interface,warning wds1238: bridge port received packet with own address as source address (xx:yy:zz:00:00:86), probably loop
08:38:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:39:21 interface,warning wds1227: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:40:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:41:21 interface,warning wds1238: bridge port received packet with own address as source address (xx:yy:zz:00:00:86), probably loop
08:42:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:43:21 interface,warning wds1227: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:44:21 interface,warning wds1227: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
08:45:21 interface,warning wds1238: bridge port received packet with own address as source address (xx:yy:zz:00:00:86), probably loop
08:46:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
08:47:21 interface,warning wds1237: bridge port received packet with own address as source address (xx:yy:zz:00:00:81), probably loop
09:06:21 interface,warning wds1241: bridge port received packet with own address as source address (xx:yy:zz:00:00:83), probably loop
The macs are unique
wlan1 xx:yy:zz:00:01:82
wds1239 wlan1-guest xx:yy:zz:00:00:83
wds1238 wlan1-home xx:yy:zz:00:00:85
wds1237 wlan1-iot xx:yy:zz:00:00:82
wlan2 xx:yy:zz:00:01:81
wds1241 wlan2-guest xx:yy:zz:00:00:84
wds1242 wlan2-home xx:yy:zz:00:00:86
wds1240 wlan2-iot xx:yy:zz:00:00:81
Hope to be clear. Obviously I can send the conf of both AP in order to solve this issue.
Another strange thing: the contents of “File” disappear any day! I made few backups in order to revert any my error, but I find always the dir empty!
Cheers
Angelo
PS as usual sorry for my poor English.
