Hi.
I have mikrotik RB750Gr3 with RouterOS 6.42.9.
I set up l2tp server over IP/Sec using this manual https://github.com/bomsi/l2tp-ipsec-tutorial
The problem is when I try to connect to mikrotik connection is established. Everything is working until I try to use Internet. If I try to load the tunnel with traffic (even browsing the internet) connection fails and router reboots.
In the log where is just this line “memory - system, error, critical - router was rebooted without proper shutdown”
Can someone please help me and tell at least where to look for solution?
Also same mikrotik is configured as l2tp client and connects to another office. Can it be interference of some kind?
