Location 1 has an rb 450g
Location 2 is my main ‘vpn concentrator’ – i have 1 rb45-g, and 1 virtual machine on hyper-v (with a routable public ip)
Location 3 has an rb 750g.
All running 4.13.
Using rb450g on location2 everything works ok (i get ip’s from dhcp in location 1 and can ping everything from enywhere). Using the virtual machine in location 2 i cannot get ip’s on computers on that location (but the bridge interface get’s an ip – using dhcp from location 1). it’s like the bridge doesn’t want to forward traffic to the lan interface of the virtual machine.
The virtual machine has 4 interfaces, all ‘legacy network adapter’ ->dec21140 emulated.
If you’re sure the config is the same (/export with machine specific things removed on on the 450G, copy and paste on the virtualized router) it’s an issue with the simulated hardware. I don’t think RouterOS has been tested with Hyper-V. If you have to emulate, try VMware - that seems to work for people.
