I have 3011 as GW with capsman manager. I have 4 cAP, everything in bridge mode (eth1,2,wlan1,2).
Now I`d like to separate 5GHz clients from 2.4GHz clients.
My setup:
- I created bridge-wifi with 192.168.10.1/24 addressin the GW(capsman)
- I`ve setup dhcp on the bridge-wifi
- I Made 2nd datapath2 (no bridge, no local or client forwarding) in the capsman.
- I edited config for 5GHz and change to datapath2
5 Restarted caps client in the both APs
But now I can see the both radios in the CAP interface but the both are the shadow (XS not RS) and 2nd connect after 20minutes with no error in the log.
I could see this in the log:
22:40:33 caps,info AP_mk_obchodaci_strop-2: selected channel 5640/20-eeCe/ac/DP(27
dBm)
Radio was disconnected in the manager (CAP interface, empty MTU) and iconnect itself after 20min.
Where is the problem or what is the best way to make diiferent LAN managed via capsman?
I have several networks with quest networks in 2.4GHz in the different subnetr and all are working properly.
ROS 6.49.2 in all boxes.
